Radio Hack Job
spitfirees20
38
Whoever had the car before me... wow. Hacked the wires all up, there is barley any wire left at all. I managed to strip all of them, and I worked at a garage so I got the wiring diagrams for the radio (which is the one with the built in amp, don't know what that system is called), but I can't get my hands in there to attach the really, really small wires to the harness of my headunit. Does a wire connector/crimp exist where I can just slide the two ends of the wires in and press a button or something so they are togethor? That's all I really have room for, and there is no way I am going to take everything apart and rewire another car (my last car it was necessary). :mad:
That connector where you slip two wires together and press down is a really bad way to wire up a connection. If I was you, I would find a way to get in there and wire up some good wires again that will hold over time. It's just gonna be funky to makeshift a crappy connection and then have the possibility of having to go back in there again if it comes lose. Check Autozone for connectors. There are some where you enter a piece of wire on each side and crimp. Good Luck! I had the same issue with my 96 Stang and I just took apart my dash and extended the connections.
Well if they have those type of connectors at autozone, I may have to take a trip there. Thanks for the tip :nice: I would fix the wires permanently or rewire the whole thing, but my last car (truck actually) was a jeep cherokee that I built, and one of the things I did was rewire the whole car with crossovers, amps, the whole works. I never want to do that again, and I'd rather fix a connection that breaks than rewire the whole car.
