Radio Problems ????
  • Thread starter Thread starter Quick Pony
  • Start date Start date Mar 8, 2008
Quick Pony
129
Pensacola, Florida
Mar 8, 2008
  • Mar 8, 2008
My factory radio stopped working on my 1991 LX 5.0 convertible. I tried another used factory radio still no sound. On both units everything lights up, but no sound. I can even hear the rollers turning when I put in a cassette tape. All fuses at fuse box have been checked and are working. Awful strange that all 6 speakers do not work!!
I disconnected the amplfier that was behind the radio(it had 2 plugs), reconnected the radio plugs and still no sound!! I thought by disconnecting amplifier, radio should work, WRONG!!
I want to get an after market CD receiver. Will I still use the factory amplfier that I have or can I throw it out. (I don't know if its working or not).
Also, will the aftermarket radio connect to the amplifiers plugs that I disconnected or to the radio's plugs that connect to radio?
Will I have to do any cutting or does everything hook up to existing plugs?
Thanks
Larry
backfocus
254
Little Rock, AR
Mar 8, 2008
  • Mar 8, 2008
Sounds like you factory amp went south on you.
If you go with a new unit you will need a install kit and the by pass connectors to do away with the factory amp.
Quick Pony
129
Pensacola, Florida
Mar 8, 2008
  • Mar 8, 2008
But, if I use a bypass harness on my new aftermarket receiver, will all of my 6 factory speakers work?
Does the bypass harness connect to the factory radio connections, (1 black, 1 grey), or to the amplifier connectors,(2), that I removed off the stock amplifier?
Thanks
Larry
backfocus
254
Little Rock, AR
Mar 8, 2008
  • Mar 8, 2008
Yes they should if you get the correct by-pass connectors. If I remember correctly the fronts are tied together anyway after the connection, but I could be wrong.
But they will work. Give Cructhfield a call they have very nice connectors they make themselves, not that junk that you get at Wally World.
The factory head unit does not have powered speaker outs is why it has the amp in the first place. If you buy an aftermarket, you could by non powered, if you want to run a full aftermartket amp setup. Most people stick with powered head units as they are usually cheaper and are just as good for listening through you normal speakers.
You could run all new wire instead of the by-pass as well.
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
G
Help! Radio, door chime fuse keeps blowing.
  • goofyfoot53
  • Sep 9, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Sep 9, 2025
91AOD5.0LX
Y
2004 Roush - Dome Lights and radio not working
  • Yurei
  • Nov 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 20, 2025
squeak93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
