D drewzx3 Active Member Feb 7, 2004 411 1 28 Louisiana Oct 11, 2005 #1 Oct 11, 2005 #1 Will the rag joint from a 98 mustang fit a 95?
juiced_94gt Active Member Mar 30, 2005 1,143 0 36 Southern California Oct 12, 2005 #2 Oct 12, 2005 #2 yes the steering shaft is the same 94-04
9 95Mustang302 Member Mar 30, 2005 302 0 16 Oct 12, 2005 #3 Oct 12, 2005 #3 where can I get a rag joint???
juiced_94gt Active Member Mar 30, 2005 1,143 0 36 Southern California Oct 12, 2005 #4 Oct 12, 2005 #4 you need to get the whole shaft unless you buy the flaming river adapter to make your stock shaft a solid one, you just need to modify your stock shaft slightly and have the new solid joint welded (spot welded to hodl it in place)
95COBRA241 New Member Sep 3, 2005 339 0 0 Delray Beach, FL Oct 12, 2005 #5 Oct 12, 2005 #5 Ford sells the stock rag joint or Flaming river sell a shaft with the rag loint replaced with metal u-joints
