Hi guys,
I have a Randall rack on my 65 (installed a few years ago), and until now I've been rather happy with it.
Apart from the turning radius crapola
So I got myself the Pro-motorsport bump steer kit, which from what I read left right and center gives you a better turning radius.
It's now installed, but... I can't do a left turn, I mean a standard left turn into a street ends up in a 3 points turn
The driver side sleeve that connects the outer rod to the inner rod is hitting the craddle on a full lock to the left.
On a full lock to the right, the passenger inner rod is hitting the cradle.
I've found this post from 66Runt
http://www.stangnet.com/mustang-forums/6416791-post47.html
I too have the straight sleeves.
Do I need the bent sleeves? Or do I really need to grind/cut the cradle?
or is there another solution.
thanks for the help guys, much appreciated.
in regards to the tie rod sleeves mine are straight. This did necessitate beveling the trailing edge of the cross brace starting about 3.5" in from the end on each side. Otherwise the tie rods would have hit at full lock with the suspension fully extended. Like coming out of a tight corner hard on the gas (think auto-x). Not cutting back the cross brace would have limited the turning radius in this condition.
, ok just need to get the toe-in right...
