  • SN95 4.6L Mustang Tech
Random Tire Question
  • Thread starter Thread starter stng
  • Start date Start date Jan 9, 2006
stng
182
  • Jan 9, 2006
So I have a question for you guys about tire sidewall height. I have been looking at other peoples rides and I am noticing that a lot of guys go with a SHORTER side wall height on the REAR tires? Example 245/40/ZR17 on the front and 255/35/ZR17 on the rear. Why would someone do this? Woudnt it make the front of the car higher than the rear? It would seem to me that you would want it the other way around?
Thanks in Advance
Don
wannabe2000GT
138
upstate, ny
Jan 9, 2006
  • Jan 9, 2006
it gives it a better rake so that the back is a tad higher than the front giving it the old school muscle car look. thats how mines setup
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Jan 9, 2006
  • Jan 9, 2006
well i run 245/45/17 out front stock size on a 17" rim
and 275/40/17 out rear on the stock rim ................but the overall diameter is close it is only off by a couple tenth of an inch like .05-.10 or so, the reason is the tire is bigger so with a 275 with a 40%(275/40) profile would be the same or close a 245 with a 45%(245/45) profile but it be wider giving it a better look
tomustang
Psychotic Member
3,434
McLean Hospital
Jan 9, 2006
  • Jan 9, 2006
the wider the tire, regardless of the sidewall height, will be taller
triggz
1,218
Gadsden, AL
Jan 9, 2006
  • Jan 9, 2006
That's incorrect, and simply not how tire sizing works.
a 245/45/17 tire is 25.68"
a 275/40/17 tire is 25.66" - significantly wider, yet slightly shorter.
stng, the reason you see a different, lower aspect ratio (middle #, the % of width that the tire will have in sidewall height) for the rear is because many people run a bigger tire out back. when the tire width (first #) increases, the aspect ratio must decrease to retain original overall tire height.
Malevolyn
18
Lakeland, FL
Jan 9, 2006
  • Jan 9, 2006
I'd like to point out that, at least on my car and most SN95 Mustangs (V8, at least) I've seen, the rear is already higher.
stng
182
  • Jan 9, 2006
Thank You all very much... I have been wondering about that for a while but didnt want to look stupid by asking...
tomustang
Psychotic Member
3,434
McLean Hospital
Jan 9, 2006
  • Jan 9, 2006
ah, didn't see the different aspect ratios
J
jimfitzgerald
6,672
  • Jan 9, 2006
This is the correct answer. Multiply the tire width by the aspect ratio to determine the sidewall height (in milimeters). Divide answer by 25.4 to get inches.
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
O
Good all around perfornace-ish tires?
  • optionizerSS
  • Jan 25, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
TPony
H
Best tire size for 91 Fox 18x9 wheels. On coilovers
  • hassler
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
KRUISR
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
