re-build kit question?
  • Thread starter Thread starter 88stangmangt
  • Start date Start date Feb 24, 2004
88stangmangt
2,332
Stafford,VA
Feb 24, 2004
  • Feb 24, 2004
summit sells 2 kits for the same price except one says .010 in. rod/main bearings and the other says standard rod/main bearings. what does it mean? what is the diff? which one should i get?
banditmwp
218
Opelika/Auburn, AL
Feb 24, 2004
  • Feb 24, 2004
the .010 rod/main bearings are a little thicker for a re-ground crankshaft. If you aren't regrinding your crank, then get the standard.
89roadster
1,124
Kent Island, MD
Feb 24, 2004
  • Feb 24, 2004
Is the .010 in. for the outer or inner diameter of the rod/main bearings?
BarnStang
1,260
Hagerstown, MD
Feb 24, 2004
  • Feb 24, 2004
Inner. They are "Undersize" meaning the are ten thousandths "smaller" than standard. Because if you get the crankshaft ground, they will take an even ten thousandths off all the main and rod journals. The crankshaft journals will be ten thousandths "smaller" than stock when measured with a micrometer. So, the bearings need to be smaller to fill the gap.
You need to have a machine shop check out your crankshaft to determine if it needs reground or not first. If it does, then they will do that work, and you order the ten under rebuild kit. If not, then they will polish the journals to remove any small scratches or deformities, and you can order the standard size rebuild kit. The bottom line is that your machine shop needs to let you know what to get.
You can determine this yourself with a shop manual and a mic, but it's far safer and faster to have a machine shop do it. They do it every day. If its a good shop, they will not make any mistakes.
Hope that helps.
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
Suspension Maximum Motorsports Tapered Bumpsteer Kit MMTR-2 - Replacement Spherical Rod Ends
  • AeroCoupe
  • Mar 30, 2025
Fox 5.0 Mustang Tech Mar 30, 2025
AeroCoupe
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
