  • 1994 - 1995 Specific Tech
Re-Setting The Computer
  • Thread starter Thread starter rude_life
  • Start date Start date Jul 15, 2005
rude_life
372
  • Jul 15, 2005
OK i was doing a thread search because im having some rough idle issues and this guy here says he did some research and discovered he had to re-set his computer.. (3rd Post Down) http://forums.stangnet.com/showthread.php?t=562665&highlight=rough+idle . I didnt know you could do such a thing, and if you can and its safe, i wouldnt mind looking into that. Anybody have any info on this?? Please enlighten me.
Thanks...
Kris
94-302-vert
1,947
NE CT
Jul 15, 2005
  • Jul 15, 2005
I would say to clear the codes then disconnect the battery and let it drain for like 5-minutes or so. I know disconecting the battery works on mopars...
SQUEEZE&STROKE
SOUTHERN CA
Jul 15, 2005
  • Jul 15, 2005
Disconnect The Negative Terminal, Then The Positive And Wait 15 Minutes, Then Hook It Back Up
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 15, 2005
  • Jul 15, 2005
Disco the neg batt cable, step on the brakes for about 5 seconds and .......
your good to go.
Or just disco the batt for about 20 mins.
Either way, the clock should read 12:00.
Later
Grady
rude_life
372
  • Jul 15, 2005
OK then scratch that ive done that about 10 times in the last month, last time being yesterday afternoon when i replaced my battery. Idle Issues and pingage!! I guess it doesent help that it was 108° yesterday and 109° today where i live.
rude_life
372
  • Jul 15, 2005
Please help.
94-302-vert
1,947
NE CT
Jul 15, 2005
  • Jul 15, 2005
Did it start with any one mod?
I am almost thinking a small vacuum leak...
SQUEEZE&STROKE
SOUTHERN CA
Jul 15, 2005
  • Jul 15, 2005
WELCOME TO THE WONDERFUL WORLD OF OWNING AN SN95. This is something that everyone experiences who drives where its hot. You can try anything and everything but untill you change the computer its going to continue. I experienced the same thing until I changed the computer to an A9L. If you want to convert it I have the conversion harness with computer and BAP sensor for sale
rude_life
372
  • Jul 15, 2005
I am pretty sure it started when i set my timing back from -6° to 10° stock. Thats when the pinging started. When i open my hood after driving it almost smells like sweet. Does that mean im running lean? I installed an adj. FPR and i dont have a gauge so i dont know what it is reading, when i installed it i had one of those regular PSI gauges that you plug into your fuel rail, not a stationary one. That is how i set the FP when i installed the FPR but since then i have tinkered with the FP back and forth in the hopes it would make some improvement so now i dont know what the hell it is at.
Just for the record here is everything i have done in the last 2 months in terms of replacement parts.
New Parts: Fuel Pump, Fuel Filter, ADJ. Fuel Pressure Regulator, PCV Valve And Screen, 02 Sensors, Coolant Temp Sensor, Air Charge Temp Sensor, New Mass Air Flow Sensor, New Coil, Cap and Rotor, Plugs (gapped), Wires (FRPP 9mm)
P.S. >> I Always 91 Octane Fuel. Recently cleaned and oiled K&N Filter
SQUEEZE&STROKE
SOUTHERN CA
Jul 15, 2005
#10
  • Jul 15, 2005
  • #10
GET A GAUGE SO YOU CAN FIGURE IT OUT. IF THE FUEL PRESSURE IS TOO LOW IT WILL DEFINATELY CAUSE PINGING. I GOT GAUGES FOR SALE TOO A RAIL MOUNT 1.5" AUTOMETER AND AN AUTOMETER 2 1/16" SPORT COMP MECHANICAL.
rude_life
372
#11
  • Jul 15, 2005
  • #11
Didnt know you lived in Palmdale SQUEEZE. And youve got all that stuff for sale.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Jul 15, 2005
#12
  • Jul 15, 2005
  • #12
Sweet = Coolant ..... unless you're running like Turbo Blue or something.
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
R
1974 Datsun 620 pickup / 5.0L HO
  • RJH46
  • Aug 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 24, 2025
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
