Re-use Ford's Lock Bolt for Differential Cross-Pin?
Eulers
57
Hello Diff Experts. Is it significantly risky to re-use the original Lock Bolt for the Differential's Cross-Pin? With LocTite I would add upon reinstallation?
I used a 6-point 5/16" wrench to remove the Lock Bolt. It is the original Ford Lock Bolt and it only has been removed this once. Removal took some firm pressure at first but unscrewed with no fuss. The drive faces of the head of the bolt are still sharp & in good condition. The rear end has over 150,000 miles on it.
My only other alternative in my local area is a Dorman 81048. However, I am not so convinced of Dorman's quality. I fear a new Dorman would break/shear upon future removal before the re-used 1987 Ford Lock Bolt would.
Are there flex fatigue cycle concerns from the Cross Pin that would have me discard the Ford original Lock BOlt?
THanks
Application: '87. All stock. All original. 8.8 rear. TractionLok. Street duty only. Lock Bolt brand is Ford. Lock Bolt vintage is 1987.
  • Sponsors(?)
Mustang5L5
Put lubricant all over the balls
Mod Dude
Feb 18, 2001
37,338
13,172
224
Massachusetts
I reuse.
the cross pin is not torque to yield. It’s only torqued down to prevent it from backing out. It’s body is in shear to keep the cross pin from backing out, and the cross pin isnt really in load trying to eject itself from the diff.
short of overtorquing it, it should easily hold up to any abuse thrown at it.
Shakerhood
3,313
185
114
Ohio
I replaced mine the last time l was in there but doubt it matters one way or the other.
Reactions: 1 user
TIGGER
550
68
69
Portland, OR
Visit site
I have always used the old ones as well. However a couple years ago when I rebuilt my rear on my Saleen, I replaced it with the new one that came with the clutch kit. Only thing I didn’t replace at that time was the axles. After ~200k the drivers side started seeping gear oil. I Bought some replacements axles last month. This weekend I decided to swap them. Stupid pin broke at some point. Took me a couple hours to get the piece out today. I’m putting the original one back in tomorrow when I button it up.
Eulers
57
I reuse.
Good point - it's not torque to yield. Thanks!
Eulers
57
Interesting. THanks for sharing your experience. Looks like I will be reusing the original Ford bolt. Thanks..
Reactions: 1 users
