Read this if you are doing a turbo coupe rear disk Brake swap !
mat50ho
128
EGF, Minnesota
Just finished up a turbo coupe brake swap on my 89 mustang with stock length axles. I though I would post some usefully info to save you some time and money.
Starting at the front of the car. If you use a master cylinder from a 95 mustang you will need the reservoir also they are not interchangeable.
The brake booster install form a 95 will take time and Patchiness’. Plan at least a day to complete the booster and master cylinder swap. If the motor is out of the car it will make it a lot easier.
I used the proportion valve from summit part # SUM-G3905.
Ford plug for gutting stock purporting valve part # FMS-M-2450-A
I put hawk brake pads in the front with 73mm calipers part # HWK-HB125F-650.
The parking brake handle will have to be modified. Here is a link that will explain http://www.mustangcentral.net/tech/brake.html
you will need new parking brake cables 1 part # FMS-M-2810-A and two part # M-2809-A. Summit sells both.
I used motor sports brackets that were cut and fit over the axle. If you don't what to cut and fabricate you can buy other brackets. Link http://www.northracecars.com/catalog/brakes/brakes.htm
I did have to shim the brake brackets inward a 1/4". Witch makes me wonder if I would have used the North racecars brackes. I may have had to machine off the 1/4 ". BTW I have superior axles and an auburn locker.
Brake lines
if you are going bend the stock lines to fit no cutting and flaring you need 2 parts # 7818 weather head break fittings form Napa. They will convert the factory 3/16 fitting to the brake hose fitting.
Or for 30 dollars 40 for ss lines and a much nicer look. Classictubing.com makes the lines for the swap. You have to call them and ask for the M-2300 conversion lines for an 87-93 mustang. When I talk with them it takes 10 + days for you to see the lines so order in advance.
Brake hoses
You will need rear brake hoses from a 95 mustang GT. I ordered the ones from a 87 Thunderbird 2.3l turbo coupe and they were wrong.
Here is a few more links to help http://www.corral.net/forums/showthread.php?t=756799
http://www.duggerracing.com/techtips...s/index1.shtml
www.sn95brakes.com
Matt
Been there and done that, have the Tee shirt... See my sig...
I used the stock booster and saved myself a bunch of time and pain. I have excellent pedal feel and modulation. I used the Turbo Coupe rear axles and saved myself more touble and pain. The driver's side tire shows some evidence of rubbing against the inner fender lip, but it did that before when I ran 225x65x15 tires.
All the documentation for the TC rear axle swap is on Matt90GT's site, http://www.svo73mm.cjb.net/. I highly recommend that anyone contemplating a brake or rear axle swap read the site from start to finish. Just about everything you would need to know is there.
