I finally ready to swap cam.I gotta trickflow stage 1,I'm going to use 1.7rr with it.Here's my mods so far,Eddy Performer heads(1.9,1.60),cobra int,afpr,1.7rr,65mm tb,76mm maf,a/c delete,underdrives,off road hpipe,bbk unequal shorties,silencer removed,19lb inj,190 fp,2 chamber flows,3.73,5sp.Anyone running this set up? or something close.Are you happy with the cam?Any problems with valve clearance?Any input would be appreciated.I can't swing a custom grind cam,is there cam that would work better?I could return if there is.
