Real quick and easy question plz help
  • Thread starter Thread starter 1_bad_GT
  • Start date Start date Oct 14, 2005
1_bad_GT
  • Oct 14, 2005
hey guy i got a 91 mustang gt and need to no what kind rear differential (sp) fluid to put in her? is it like 80w 90? im assuming i need stuff for a limeted slip diff? thanx for the help
dirtysohc
103
High Point N.C.
Oct 14, 2005
  • Oct 14, 2005
I use Royal Purple synthetic 75w90. 80w90 is fine as well.
slow93
406
  • Oct 14, 2005
i use 80w90 and yes make sure it is for limited slip
dirtysohc
103
High Point N.C.
Oct 14, 2005
  • Oct 14, 2005
slow93 your avatar makes my pants grow uncomfortably tight.
1_bad_GT
  • Oct 14, 2005
yea i bought the stuff today is 80W 90 and for limited slip just wanted to make sure before i put it in, thanx alot, also u guys no how much it will hold?
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Oct 14, 2005
  • Oct 14, 2005
Are you saying the gear oil you bought is approved for use in limited slips or are you saying you bought fluid with the limited slip additive already in it
slow93
406
  • Oct 14, 2005
off the top of my head i think it holds about 2 1/2 quarts...dont hold me to that though
slow93
406
  • Oct 14, 2005
i dont think im ever gonna get tired of that av!
D
Daggar
3,902
  • Oct 14, 2005
I think the term "friction modifier" is what's missing.
vristang
4,933
101
124
Seattle
Oct 15, 2005
#10
  • Oct 15, 2005
  • #10
1_bad_GT
#11
  • Oct 15, 2005
  • #11
It says sutibul for limeted slip on the bottle
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Oct 15, 2005
#12
  • Oct 15, 2005
  • #12
Then I would call the company that makles it and ask them to hire an editor to proofread and make corrections on the poor spelling they put on the bottles ....
You need an additive to go in with the gear oil ...
A normal size tube of friction modifier.
You put the complete contents of the tube in before any gear oil ... ask your local parts store ... they will know.
1_bad_GT
#13
  • Oct 15, 2005
  • #13
k got all that done and she's hookin posi again, also i want to change the tranny fluid seeing as how i just got the car. and if what came out of the rear end is any thing like the tranny fluid im in trouble. so do i just put 80w 90 in the tranny to??? and where is the drain plug? filler plug? i never really looked and im sure u guys will no right away. thanx again for all the help
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Oct 16, 2005
#14
  • Oct 16, 2005
  • #14
Since the assumption can be made that the car is Mexican shift ("Manuel") ... all you need is DexronIII/Mercon automatic tranny fluid.
The drain and fill plugs are on the passenger side of the transmission case.
Since the plugs have a female square shape in them, all you use to take them out is a 1/2" drive ratchet.
The lower plug is to drain the fluid and the upper is to fill ... it works off gravity
Pick up a quart bottle or gallon bottle fluid pump ($5) at your parts store, since you will need it to pump the ATF back into the tranny.
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
