When people swap their intakes, what do they change out? The lower or upper manifold? I think the upper is the most restrictive but I'm not too sure.
Disagree...You dont "need" heads. There are many guys that just change the U/L intake, do exhaust, a new MAM, CAI and some pulleys and do ok. The heads make a lot of power, but again, theyre not "needed".17yostanger said:with you mani, you need heads
you CANT put a performer upp manifold on the stock lower...it wont bolt up...17yrOldStanger said:upper and lower. if you put a performer upper plenum on that stock lower, youd be wasting money. everything needs to match. with you mani, you need heads. with the heads, you need headers. with a stang, you need a turbo or super![]()
94GTLaserRC said:If you have an Edelbrock lower, you can put the Performer 5.0 or the RPM.
Some guys put the Performer 5.0 with the Edel. Lower for a fairly stock setup, and then change out to the Performer RPM or RPM II when they get more mods.
Chowder Head said:Oh okay so the lower manifold is the most restrictive out of the two?
When would be a good time to get a better upper manifold? Any reccomendations on manifolds or is Edelbrock one of the best out there?
Thanks.
I agree b/c I did the same mods at the same time, MAF, CAI, U/L & 65 mm tb. WOW what a difference it made! Be careful b/c after that you will start modding the hell outta your car after that.94GTLaserRC said:One further note:
A fairly easy upgrade, which my friend had done in 1999 with his 95 stang, was to (well at that time, Steeda did it) replace the U/L intakes, TB, and MAF. He said the car felt like a new "animal"
I would say you could also achieve that with a new MAF, a CAI, and a new U/L intake, but you could save the $$ and keep the stock TB.
RC
tmoss said:Another option not mentioned is to get the stock lower intake ported -.
I know that..I guess what I meant was HOW MUCH would it benefit me, and would it be worth it?tmoss said:With a power adder like a blower, it's always good to open up the flow path - both heads and intake.
94GTLaserRC said:First off, you should post your mods, so we can better help.
Secondly as mentioned, you will not ONLY REPLACE THE UPPER!.
You have to do them together...
If you are fairly stock, my (and others may disagree) recommendations would be one of the 3:
1. Used Cobra U/L (look nice and they polish and paint up nicely)
2. Edelbrock Performer 5.0 upper with the lower.
3. Trick Flow Street Heat upper and lower
Number 2 of the 3 choices will probably cost the most right now (but not a lot more), but if you upgrade the combo, you can change out the upper only.
If you go #1, you may be able to save some $$ (since it is used), but you have to be careful of what you are buying.
Good luck!
RC
Chowder Head said:Opps my bad for not listing mods.
Well right now I am stock but I plan to have either a 331 or a 347 stroker in there with a set of AFR 185 heads. Any reccomends on the 3 intakes you mentioned that would do the best for me? Oh BTW, I plan to turbocharger later on too.
Thanks a lot.
94GTLaserRC said:If it's gonna be awhile for the stroker (which I bet it is) you will benefit from an Edelbrock Performer 5.0 intake now, and then just swap out the upper for an RPM or RPM II later.
Im not knockin you, but I wish I had a dime for every guy who said "Im doing such and such" when I joined here and they still havent done it...
H3ll..my mods sat in my garage for 8 months before I got them on the car!
RC
