- Nov 7, 2005
- 121
- 1
- 0
The driver's rear 1/4 window on my 90 conv has quit working. I've removed the window motor and the bushings inside are in a much of very small pieces. Here's my problem, the window itself seems real loose and can be moved back and forth at least 1/2" either way. Is this normal? Is there some part of the window linkage that needs to be fixed? anyone with a diagram of the window linkage or a good description of how it operates?
