rear brake bleeding problems
  • Thread starter Thread starter iapexl8r
  • Start date Start date Nov 20, 2005
I
iapexl8r
254
Nov 20, 2005
  • Nov 20, 2005
well i have an 88 mustang with a new factory powerbrake booster, new 95 gt 1 1/16" master cyclinder, proportioning valve (adjusted to full increase also tried full decrease)a mm plug for factory dist block, pbr cobra front calipers, and svo rear calipers.
Now we get to the problem: when I try to bleed the brakes the flow out of the rear brake bleeder screw is minimal at best.
the master cylinder was thoroughly bench bleed prior to starting.
heres what I tried: the way Ive done it for ever, the old lady in the car give the pedal 3 pumps and hold, I open the right rear (thats where Ive always atarted) this was done first with the proportioning valve full increase very little flow out of the right rear bleeder screw. ran the proportioning all the way decrease same result very little flow. also tried opening one of the front caliper bleeder screws(great flow out of the front caliper) left it open wile I tried the rear (this time tried both rears, prop valve back to full increas as per instructions) same results low flow out of rear brakes. the tried removing the e brake cable and zip tieing the e brake lever on the caliper to the full off pos no help. well Iam stumped. am I missing somthing???? thanks in advance. the worst part of it is it is about 80deg clear sunny skys and a I want to do some sunday driving. chris
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Nov 20, 2005
  • Nov 20, 2005
5 possible scenarios:
First, you didn't take out the necessary items from the stock PV (under the MC) that control the rear brakes. Check here:
http://www.mustangcentral.net/tech/brake.html
Second, you didn't adjust the aftermarket PV correctly. Make sure you have it cranked all the way in for full pressure to the rear brakes.
Third, a line is leaking somewhere and releasing pressure from the system
Fourth, the booster rod may not be properly adjusted so it isn't pushing the bore of the MC very far at all. Check to see when the pedal actually engages. If it is low to the floor then you will likely have to adjust you booster rod 1 turn out.
Fifth, you may have to take your rear caliper off to get all the air out. The bleeder screw needs to be at the 12 o'clock position.
I ended up getting a pressure bleeder to do my system and it worked great. Keep us posted.
I
iapexl8r
254
Nov 20, 2005
  • Nov 20, 2005
thanks for the advice, just found the problem. it was the factory rubber hose going to the rear end was swollen shut not letting fluid to the rear brakes. just pulled it off and I cant even blow through it. Have herd about this before but never seen it well there you go thanks Chris
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Nov 20, 2005
  • Nov 20, 2005
Whoops, 6 scenarios .........
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Brakes How do I get the e brake cable onto the disc brake caliper??
  • AnthonyA1234
  • May 2, 2025
Fox 5.0 Mustang Tech May 2, 2025
AnthonyA1234
P
Rear disk brake caliper parking brake adjustment
  • parrotguy
  • Oct 23, 2025
1974 - 1978 Mustang II Talk & Tech Oct 24, 2025
2Blue2
Brakes Front brakes sticking - 1988 5.0
  • 302Blue
  • Oct 18, 2024
Fox 5.0 Mustang Tech Oct 19, 2024
ustacould
