Ok all here is the deal.
I had a new set of rotors / pads put on about 6-7 months ago along with my suspension kit. Since then I have had a squeek in my back brakes. The squeek is there when I am NOT on the brakes. Just the littest pull on the ebrake or a little pressure on the pedal they shut up.
I have tried 3 different brake pads, different brands too. Even turned the new rotors once already to make sure they are flat.
So what could this be?
-Could my cobra brakes up front be causing me problems? Pressure valve?
-Bad rotors (they are brembos)?
-Brakes are just screwed up?
The car is at the shop now since they are putting on new tires and are going to look at my brakes again.
The shop is thinking it is a heat disipation problem so they suggested I may need new drilled or slotted rotors? They do squeek more when warm, when cold in the AM they are usually quiet.
Ideas?
~K
Ideas?
~K
I would guess you could pick it up at any autozone/pepboys/whatever shop is closest.
