Rear Brake Trouble Or Axle Bearing Or ?
NVERL8
72
42
Cincinnati
Hi everyone, need some serious help diagnosing an issue on my 65. If I take the car for about a 10 mile drive something on the drivers side rear wheel is heating up enough to cause minor smoke. By the time I pull everything apart I cant tell where the smoke is coming from. The brake drum is very warm when I get to it (much warmer than the passenger side) but it is free and not difficult to turn at all, and I don't have the normal brake dragging smell or any smell at all for that matter. If I press the brake pedal hard and let go the brake is free. The pads look very worn but since I do not get any drag I am not sure what the issue is. My other thought is wheel bearing allowing the axle to move some and contact the brake shoes however when I run the car I get no noise from the back and when I have the drum off and manually look for play the axle is tight.
My first thought was to try a new wheel cylinder and pads, but since I get no drag one the jack stands playing with everything I don't know if this would be a waist of $$$$. Plus I used the adjuster to adjust the brakes in a lot and got the same results on a test drive
If it might be the axle bearing I would have a buddies shop do but I do not have any other symptoms of bearing failure and really don't want to take it to him if a brake job is all it needs.
What am I missing?
  • Sponsors(?)
tos
SN Certified Technician
Apr 27, 2001
896
68
59
Cincinnati Ohio
If your bearing where getting that hot it would have failed by now or at least making noise. Plus you likely wouldn't see any smoke. Its got to be the shoe rubbing the drum. What does the surface of the drum look like? Can you post pics? Can you still rotate the drum with the car running (or does it not make a difference running or not)? Is the other side rear brake definitely engaging?
NVERL8
72
42
Cincinnati
Makes no difference with the drum on or off or running or not running. I can spin everything freely with my fingers. The drum does not look bad and no uneven wear. Brake oad wear does look un even though.
tos
Apr 27, 2001
896
68
59
Cincinnati Ohio
[QUOTE="Brake oad wear does look un even though.[/QUOTE]
You mean one shoe is worn more than the other on the same side?
Did this start happening out of the blue or did you do some work in this area recently?
NVERL8
72
42
Cincinnati
not really, mostly like it is wearing more in the center of the shoes and not so much around the edges....... very strange
tos
Apr 27, 2001
896
68
59
Cincinnati Ohio
That just indicates that the drum is a slightly larger diameter which means a bigger radius than the shoes. Probly due to the drum being turned a time or two.
So the only thing I can guess at this point giving the information is that maybe only your drivers side brake is working in the rear but the passenger side is not, or just barely and the drivers side is doing all the work? This would explain getting that hot but turning free.
Unless you have an exhaust pipe pointed directly at the area heating it up that's all I got until we get more symtoms.
NVERL8
72
42
Cincinnati
rebuilt the brakes on both sides last night and all is well. Must have been a bad wheel cylinder or maybe the original springs just didn't have enough strength to close the brakes back in....
Thread starter Similar threads Forum Replies Date
EdMac67 WTB/Trade Wanted: Parking Brake Lever for Lincoln Versailles 9" Rear End Other Classifieds 0
W rear brake size 88 lx 2.3L (N/A & Turbo) Tech 4
N Brakes Rear brake slow drip SN95 4.6L Mustang Tech 1
T I have no rear brakes 1996 - 2004 SN95 Mustang -General/Talk- 2
My92cashtrap So noobie...what rear brakes do I have? Fox 5.0 Mustang Tech 7
K Fox Rear Brakes - where in the holly heck do these go? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
C Brakes Stock fox front brakes with sn95 rear Fox 5.0 Mustang Tech 8
Red50Fox Fox rear brake backing plate bolts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
0 Rear Brakes 2001 GT Anti Rattle Clip Question 1996 - 2004 SN95 Mustang -General/Talk- 6
C For Sale Steeda (Hawk) Rear Brake Pads New 183HPS.585 Wheels Tires Brakes 0
S Reoccurring squeak/chirping noise coming from rear. SN95 4.6L Mustang Tech 1
2 Brakes Right front and left rear brakes locked up. Classic Mustang Specific Tech 6
P Brake lights and rear turn signal mystery 1965 - 1973 Classic Mustangs -General/Talk- 0
P Brake and rear turn signal lights mystery Classic Mustang Specific Tech 0
A Limited Slip Rear End Grinding and Whining 1996 - 2004 SN95 Mustang -General/Talk- 1
ZeroFoxGiven 9in rear end w/disc brakes [Parking Brake] 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
2fast4u770 Rear brakes 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
H Placing front brake calipers in the rear 2015+ (S550) Mustang -General/Talk 3
a50ina50 Brakes Brake lines for Wilwood rear calipers Fox 5.0 Mustang Tech 1
C Question on 'Cobra' rear disk brake calipers 1996 - 2004 SN95 Mustang -General/Talk- 1
A Brakes Shaving 1/16” off rear brake caliper 2005 - 2009 Specific Tech 1
M 91 mustang rear brake parts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
J Rear brake kit SVT Tech Forum 3
J Rear E-Brake Cable Replacement 2005 - 2014 S-197 Mustang -General/Talk- 3
T 1964 1/2 disk brake conversion residual valve needed for rear drums? Classic Mustang Specific Tech 8
9 How to replace rear parking brake cables? Is there a tutorial? 1996 - 2004 SN95 Mustang -General/Talk- 0
ebowie SN95 SN95 GT to Cobra brake swap... in need of rear caliper mounting brackets and anti-moan brackets 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
R Brakes 1977 8inch rear. What's the latest on disk brake conversions? 1974 - 1978 Mustang II Talk & Tech 1
O 2003 GT Vert - Rear end noise 1996 - 2004 SN95 Mustang -General/Talk- 3
D Brakes 98 V6 with upgraded rear tubular LCA looking for spot to secure e-brake line SN95 V6 Mustang Tech 0
J Please help rear brake calipers 1996 - 2004 SN95 Mustang -General/Talk- 3
cliff88145 Saleen 88 Saleen rear brakes caliper piston Special Production 0
M Where disconnect hoses for rear end removal Fox 5.0 Mustang Tech 6
montegoman351 03 front, SVO rear brake questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Nightstang00 Axles For Rear Cobra Disk Brakes 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 23
MoDriver For Sale J & M Mustang Brake Hose Kit 87-98 Ford Mustang Rear Stainless Steel Wheels Tires Brakes 0
gikort Rear Disc Brake Conversion 1965 - 1973 Classic Mustangs -General/Talk- 4
sen2two Sn95 Rear Brake Lines To Fox Stock Lines 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
MoDriver SOLD Used 94-04 Mustang Cobra Rear Brake Calipers w/ Carrier Mounts Wheels Tires Brakes 5
9 Brakes Anyone Ever Manually Change Their Brake Bias Before?(front Bias To Rear) SN95 V6 Mustang Tech 1
Matt01 Turbo Coupe 5 Lug Rear Brake Setup. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
mhjo Rear Brake/turn Signal Light Dead 1965 - 1973 Classic Mustangs -General/Talk- 2
K 1990 Foxbody Gt Rear Brakes?? Fox 5.0 Mustang Tech 3
B 90 Lsc Rearend In A 89 Fox Lx 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
92Apocalypso Expired 87-92 Rear Disc Parking Brake Cables $100 Shipped Wheels Tires Brakes 0
T Rear Lights, Blinker, Hazards, And Brake Lights Not Working On 2006 Gt Mustang 2005 - 2009 Specific Tech 4
stangboy Brakes Help!! Rear Brakes Won't Bleed After Adj Pv Install Fox 5.0 Mustang Tech 21
G Brakes Foxbody Rear Brake Line Fitting Size Fox 5.0 Mustang Tech 11
S Fox Rear Disc Brake Wheel Fitment 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
95BlueStallion Fox Upgraded Front Brakes, Stock Rear Drums? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
