rear end advice
billison
I like tinted tail
2,607
1,094
184
stl
ok, my rear is junk,
it's the 7.7, stock gears
i don't think the rear brakes were changed for atleast the last 10 years "befor i had it" the best i get out of the rear brakes is fluid to shoot out
what will be the best car to get a rear end out of, looking for the best bang for the buck
also, i'm not wanting to change the master cylender so i'm looking for an alternative to the tourbo coupe rear, but i have to get the rear brakes going for emissions,
it's a 85 auto
ninety15.0 said:
ive heard u can get complete rear ends out of SVO cars with factory 3.73's and its an 8.8". or you could grab a 99+ axle that comes stock with 3.27's.
The 99 and later rear axles are a lot wider = 1.5" per side. Unless you want to do the ricer ghetto thing with little wheels and have them stick out past the fenders, I wouldn't recommend it.
I just bought an entirely brand new 8.8" rear-end w/3.73 gears from FMS through Summit. It was around $800 to my door. It comes w/o brakes and axles, but the axles from your stock 7.5" rear-end from your '85 Mustang, and the stock drum brake setup will bolt right up w/o any problems. I know this because I had an '84 Mustang 7 years ago that I had for 4 years and did the same 7.5" to 8.8" rear-end swap on it.
If you plan to keep your car for a long time, do yourself a favor and get a new one, not a junk yarder. If you're short on money, than get a junker, but be careful not to get one with anything bent on it. Plan on at least cleaning out the old fluid, etc. and changing the axles seals and bearings.
When I weighed the options, and the cost of a junker plus replacing seals and bearings, was total was about $450, so for about twice the money I got a new one with not problems or abuse on it yet.
I managed the entire front and rear end out of a 94, all brake components, booster, MC, even the K-member (worthless lol) and e-brake cables... That stuff was $400. The rear end rebuild parts including 31 spline axles and 31 spline trac-loc will cost me another $440. Once complete and ready to install, the whole thing will have cost me roughly $850 for a 4 wheel disk brake conversion with a rear 31 spline setup. I'll toss the other $150 in for a differential girdle from Trick Flow.
Another reason I went this route is that it allows me to weld the axle tubes with no drama.
i'm on a major budgit right now " just got married" and i'd like to keep it under 2 or 3 hundred so i'm mainly looking at a junk yard rear end, i was wondering about if i cam aross one of the like 4 banger turbo gt's, what about the rears out of them, did'nt they have good gears, i can get a 4 banger rear for basicly free, would that do to just get me through the emissions test, i know it wount last long, but for a temp fix?
