  • 1994 - 1995 Specific Tech
rear end and wheel problem
  • Thread starter Thread starter smokin95vert
  • Start date Start date Jan 13, 2006
smokin95vert
53
Gettysburg,PA
Jan 13, 2006
  • Jan 13, 2006
:SNSign: Ok my problem is I installed new wheel spacers the real ones. Ok the problem i have is know you can see that the passenger side wheel sets like a 1/4 inch in farther than the drivers side wheel. Ok i was wondering is it the rear or could it be the control arms. Or are they offset from the factory. Anyone have this problem or know how it could be. Thanks Jay
ROLLIN5.0
135
Tulsa, OK
Jan 13, 2006
  • Jan 13, 2006
Hehe, my passenger side wheel sits in a full inch more than the other. I noticed it when I put the wide tires out back. I set the rear springs so that the starting coil was set at the same spot, replaced the worn out quad shocks, and inspected everything else I could think of that could possibly cause it. If you find the solution, please let me know. My car has been wrecked a couple times, so I am down to thinking that is the cause, and looking for a never wrecked 94-98 to swap all my stuff into.
Brandon
Killercanary
The car that set the bar.
Altoona, PA
Jan 13, 2006
  • Jan 13, 2006
The rear "should" be squared in the car and not sticking out one side more than the other. Was the car wrecked? Check for bent control arms, different ride height per side, etc.
94-302-vert
1,947
NE CT
Jan 13, 2006
  • Jan 13, 2006
I even think you jsut need to look for bad control arm bushings... i could't beleive hoe much my rear was moving around under the car with my bad rubber bushings. I have to say that those bushings were the single best mod I have made....
smokin95vert
53
Gettysburg,PA
Feb 16, 2006
  • Feb 16, 2006
ok found the problem it was those control arm bushings. They are so shot. So im going to order some upr upper and lower control arms. On the other hand i think that my passenger wheel in the rear looks cambered. im not sure what the heck is wrong with it. thanks jay
HISSIN50
34
129
Feb 16, 2006
  • Feb 16, 2006
Though it aint right as Paul notes, it is quite common on OEM-ish rear suspensions.
Seems to me that the spacers or wide wheels just give us a point of reference with the fender and we notice it more.
When stock, we dont say:
"Hey Bob, does it look like my RR wheel is 10" away from the fender, and my LR wheel is only 9" away?").
New suspension components and the addition of a panhard bar, etc can help locate the rear end (it tends to want to sway).
My two cents. Good luck.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
N
1969 15x10 295's for rear. Modifications needed?
  • normg
  • May 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 2, 2026
GypsyR
G
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
