- Apr 5, 2008
- 11
- 0
- 0
so the guy at the store told me i need 75w90 for my 2001 gt mustang turns out the tag on the back of the cover says 75w140 will 90 be ok or do i have to go get the 140?
BUT the only reason i went with that was because the rear end is in great need of replacement and i couldnt justify paying that much for the 140... i would always go with what ford says run... why i still use motorcraft oil and filters
thanks for the responses I put in the mobil one 75w140 and some limited slip additive![]()
I had used a Jiffy lube, and the tech pocketed the friction modifier one time when I had the diff fluid changed.
(Is windshield washer fluid that expensive?)I hesitate taking either of our vehicles to Jiffy Lube or any quickie place. I recall the last time I was at Jiffy Lube - as part of their service will top off all of your fluids...but what they don't tell you is what they top them off with...
Ummm, for the windshield washer fluid, they simply filled it with water.![]()
I wasn't quite sure, but I kinda wondered when he was filling it with what appeared to be a garden hose...when I got home, I noticed it was clear fluid - aka water.(Is windshield washer fluid that expensive?)
In addition, they typically leave oil dripping down all over the place underneath, off of the K Member, sway bar, etc - making you wonder if you have an oil leak when you spot drops on your garage floor. I know the Mustang Oil Filter is in a weird location, but come on, fellas...
Yeah, I was there once for an oil change, and they tried to put it a seventh quart of oil into the engine when all it needs is six. They were going just by the dipstick readings and they ignored the owner's manual.
Jiffy Lube will not be getting my business.
DIY ftw.
Jiffy Lube is our best customer. I love those guys. If it weren't for them, I wouldn't be replacing engines and transmissions for them. They even screw up the KIA's and myself and the KIA adviser know their corporate claims rep by name now. I love it when new customers tell us, they will be using Jiffy Lube for their oil changes during their service walk.
Funny how some of those people come in with problems due to Jiffy lube not using a crush washer on the drain plug, or the wrong oil filter is used, or they yanked on the transmission filter, saw the red fluid coming out, then tightened it back on and didn't tell anyone they put a hole in it and the rest of the trans fluid drained out. Either way you pay.
ok so I also ended up putting in some limited slip additive with 75w140 mobil one hopefully that was ok let me know if you know thanks
