Rear end please help
  • Thread starter Thread starter lsubadboy
  • Start date Start date Oct 19, 2018
L
lsubadboy
28
  • Oct 19, 2018
Does any one know what year mustang gt I can go up to to pull a rear end off and upgrade mine I have a 96 mustang gt I think mine is 273 gears what year will fit in mine without modifications please let me know
L
lsubadboy
28
  • Oct 19, 2018
Ok I found out that only 96-98 will work for mine know what if I get a rear end out of a 98 cobra will it fit and what size rear end gears did cobra have
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 19, 2018
  • Oct 19, 2018
Try this. Go to car-part.com and search for the part in question. See what other "applications" come up. This will give you an idea of what other cars will interchange with the part being searched for.
Regarding what ratio. It is possible to rebuild a Ford 8.8 rear end with virtually any ring and pinion ratio desired.
Neuron
5 Year Member
Nov 6, 2016
859
192
93
Oct 19, 2018
  • Oct 19, 2018
'98 Cobra had 3.27 ratio IIRC and I believe most if not all had ABS. Same rear end as the GT, '99 Cobra first year with IRS.
Good advice above.
L
lsubadboy
28
  • Oct 21, 2018
Good advice above.
So this should fit in 96 mustang gt without any mods
Neuron
5 Year Member
Nov 6, 2016
859
192
93
Oct 21, 2018
  • Oct 21, 2018
Yes it should, the only difference between the two suspensions is the spring rates and sway bar sizes. Driveshafts are interchangeable.
J
Rear alignment issues
  • Jayjay001
  • May 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 4, 2026
manicmechanic007
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
