Drivetrain Rear end Question
Hi
recently bought 89 GT
Found a rear end repair Reciept with some details
it came into the shop locked up
mechanic replaced gears with 373
Shimmed up everything and kicked it out the door,
It’s still the 8.8
anyway I have been driving the car, no real issues except that I noticed only 1 rear wheel spin.
Drivers side mostly unless on gravel
anyway I jacked up the rear, spun each wheel expecting to see the other go opposite
But no, I the other tries to go same direction but won’t, fast spin or slow..
can someone tell me from this, do you believe the diff is a locker, limited slip or standard diff
seems like there may be clutches in there just worn maybe??
Thanks
Andy
I don’t have a ton of experience with this, but I did just recently rebuild my own rear end. I painstakingly watched videos and read articles during the process, and in the end, it runs awesome. I would bet that all they did was change the gears and throw it back together. I’d say that your clutches are shot and need to be redone.
So the rear end in the mustang is a limited slip. It is a crappy version of one though. There are clutches on both sides that you can replace. But buy a trac lok if you want posi. It's a great way to spend 4-500$.
Rear end gears are something I grown into. The 8.8 is actually easier than say a 9 inch. If you have the capability to torque the crush sleeve it's about 220ftlbs. Then you have to use a dial caliper to measure play in the gears then paint them and spin it for like 10 minutes. It's definitely doable if you have the tools and a afternoon and some ocd helps. Also YouTube will/can walk you threw it in like 8 different languages
That gt should have a trac lok in it. As stated it probably just needs the clutches replaced. You can buy the carbon clutch rebuild kit from ford performance and do it yourself, or find someone who has experience doing them and get a hand.
They’re actually pretty stout If rebuilt with the carbon clutches
I completely disagree with this statement. I can set up a 9" on the bench. You can not do that with a 8.8". I can change pinion depth on a 9" and never have to press the pinion bearing on and off to access the shim, unlike a 8.8". I can change backlash on a 9" and never have to change the carrier shims, unlike a 8.8". The only advantage the 8.8 has is that it is an overall lighter assembly and the pinion placement is more ideal. Otherwise the 9" is not only the stronger rear assembly but by far the easiest to work on. I can have another 3rd member assembled and ready to swap out with a 9" while the 8.8" would require complete disassembly to swap gears
All that being said, I run a 8.8" for the reasons stated above, it is lighter and because of pinion placement it takes less HP to operate. It can also be built to take a ton of power, but still not anywhere near the power level of a 9"
Reactions: 1 user
Bullitt347, I still think the 8.8 is easier. You have some good points and and knowledge about them. But let's stay on topic, as it don't matter witch axel we prefer.
Lets stay on topic.... LOL...
Reactions: 1 users
Lol. You are the one that brought up the 9"
I replied to your premise.
I disagreed with that premise and gave the reasons why.
I even said I run a 8.8" rear end. It is in a 1,300 HP car.
So...yeah.
Reactions: 1 user
