Brakes Rear End Removal, E-brake Question
  • Thread starter Thread starter FoxMustangLvr
  • Start date Start date Mar 19, 2014
FoxMustangLvr
I love my Pimp
SN Certified Technician
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Mar 19, 2014
  • Mar 19, 2014
I have two fox mustang 5.0's right now, i'm taking a 3.73 drum to drum rear end and swapping into my Notch that has a 3.08. I have everything removed accept the e-brake line that goes into the drum.
My question is, what's the easiest way to remove the e-brake cable? Do I really need to take apart the springs and shoes to get in there or am I missing an easier solution?
Thanks in advance. I'm not converting to disc for a long time so you can save that comment.
88LX5.Oh
1,442
205
94
Arkansas
Mar 19, 2014
  • Mar 19, 2014
Yeah you have to take the drum off and pull the cable off the shoe and then pinch the little fingers on the cable end to push it through the plate. It's not hard, if you can swap a whole rear end this won't be an issue to you
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Mar 19, 2014
  • Mar 19, 2014
It was the last thing still attached to the rear end last night when I called it a night. I didn't really want to have to go through the process of tearing the drum brakes apart to release it if there was another faster option. Sucks because I have to do it on the rear end for the Notch too. I guess i'll be pretty good with drums by the time this is over.
Do I need to release the cable at the e-brake handle to relieve tension?
Thanks @88LX5.Oh
88LX5.Oh
1,442
205
94
Arkansas
Mar 19, 2014
  • Mar 19, 2014
As long as the e-brake isn't set (handle pulled up) you should be good to go without disconnecting anything at the handle
Rear drums dragging
  • cnorman31
  • Apr 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 15, 2025
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Drivetrain Rear brake drum question
  • limp
  • Jul 9, 2024
Fox 5.0 Mustang Tech Jul 15, 2024
limp
Rear end
  • RileyDymond
  • Feb 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
F
Rear Drum Brakes
  • Fri Guy
  • Jan 3, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 8, 2025
Scrapla347
