Rear end setup?
  • Thread starter Thread starter Djstorm100
  • Start date Start date Jan 17, 2008
D
Djstorm100
109
  • Jan 17, 2008
I have a fully bulit rear end. And I'm restoring my mustang as well (fox 91) I have lakewood uppers and lower control arms. My questions are this
What torque box are the best? When I say bes,. I mean best overall fitment, thicker metal. I've found upper and lower for 169 (wild race car brand)
I called maximum Motorsports about the upper control arms they said to use ford stock arms with ford stock bushing on each side. So you don't damange the torque boxes. I feel like the axle will have greater wheel hop/flex with this combo vs going with the bushing of aftermarket upper arms and bushing. They said that reinforcing the tq boxes will only make them last a little longer but they will eventually get damaged.
Shed some light ?
RAYZEN CAINE
51
  • Jan 17, 2008
I bought battle boxes from wild rides here’s a article from 5.0 mag http://www.mustang50magazine.com/howto/35618_wild_rides_battle_boxes/index.html They were like 150.00
samickguy15
404
Delavan, IL
Jan 17, 2008
  • Jan 17, 2008
If you keep stock uppers but box them, you'll have better arms, reduce flex/wheel hop, and not do as much(if any) damage to your torque boxes.
And it all kind of depends on the use of the car. Street/strip i would get the boxes. If it's just a fun cruiser, then don't worry about it.
W
wicked84gt350
113
West palm bech florida
Jan 17, 2008
  • Jan 17, 2008
Mm motor sports has there own way of thinking on the upper control arms. And the reason why is the upper boxes are weaker than the lower so they tell you to run the stock rubber and arms so they flex but that defeats the purpose of getting the lowers because they will be solid but the uppers will flex every where. so you have a lot of twist hop and windup in the rear not to mention the pinion angle will change. mm motorsports also tells you to run the pan hard rod which will elimiate a lot of side to side, hop and twist and much of the axle windup. the most effective rear end setup with keeping the stock design is get new better lowers and adjustable upper with the solid end bushing on the car and put the stock rubber in the axle. So you get a little bit of cussion and put the reinforcments in the boxes. I personally will be running the steeda alumin 400hp+ lowers and a good set of adjustablle uppers. flipped quads and so good reinforcements. Built up rear and a astro t5. The weakes piont will be the tranny and driveshaft.
Maryland Stang
1,656
30
39
Greenville, NC
Jan 17, 2008
  • Jan 17, 2008
This is exactly what I did. It made an incredible difference.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Suspension Rear pinion angle
  • JD1964
  • Apr 30, 2025
Fox 5.0 Mustang Tech May 5, 2025
JD1964
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
