rear end swap ?
This is the 2nd or 3rd time the same question has been asked this week. Please try using the Search feature next time.
The 94-95 rear axle is a bolt in. The axles are 3/4" wider on each side. The front calipers, master cylinder, proportioning valve and several other pieces of brake plumbing need to be changed. See http://www.svo73mm.cjb.net/ for all the details. Everything you need to know about the brake parts selection and modifications to use a 94-95 rear axle are on that web site.
