I have an 86gt that I want to put a 94 and up rear end in so I have rear disc and 5 lug axles. Would this be a direct bolt in or is there some mods needed? Thanks
This is the 2nd or 3rd time the same question has been asked this week. Please try using the Search feature next time.
The 94-95 rear axle is a bolt in. The axles are 3/4" wider on each side. The front calipers, master cylinder, proportioning valve and several other pieces of brake plumbing need to be changed. See http://www.svo73mm.cjb.net/ for all the details. Everything you need to know about the brake parts selection and modifications to use a 94-95 rear axle are on that web site.
