Rear Gridle hits my spare wheel
89MustangGX said:
It's self-clearancing -- shouldn't be a problem after a few hits.
The technical term for this is "Rev-Hone" Defined as letting nature take its course.
Use of the term in a sentence...
If the machinist did not hone the cyl bore to the proper size, you can simply rev-hone the bore with the piston. Run at about 6,000rpm for the first ten minutes after initial startup and all your problems should be solved. :jester:
You should have got this one......the load bolts are recessed.........
88GThatchback said:
Ive got the girdle above, with the recessed bolts, and it still hits the spare well. Oh well, Im just going to let it hit a few times and it should be good.
How much is your car lowered? I have the cover with the recessed bolts, and have never had it hit......... :shrug:
