Drivetrain Rear Lower Control Arm Help
Just wondering if anyone has the measurement from center to center of bushings on rear lca. I'm having issues with shearing off the support bolts on my umi lift bars and it's letting the rear twist when I launch. I don't want to weld the pivot brackets and make it a permanent item was thinking of just removing pivot brackets and mounting arm back up if dimensions are the same.
