Heres what i plan on ordering from summit, is there anything else i should consider? im also doing the clutch
FMS-M-6375-B302 Flywheel, 157-Tooth, 10.50 in. Diameter, Cast Iron, 21.0 lb., External Balance, Ford, 5.0L, Each $91.88 $91.88
FPP-2941 Rear Main Seal, Teflon®, 1-Piece Type, Ford, Small Block, Each $37.39 $37.39
RAM-88794HD Clutch Kit, Organic, 1 1/16 in. Dia. 10-Spline Shaft, 10.5 in. Disc Dia., Ford/Mercury, Kit $159.95 $159.95
RAM-BA50M Pilot Bearing, Bronze, Solid-Type, Ford, Each
Im going to reuse all my bolts, what else do i need for the install? Just my regular tools, torque wrench, and a pilot bearing puller correct? then some Brake Clean and Threadlock. Please let me know anything you think i might also need.. Thanks alot!
