I'm trying to decide what rear seal to install in a 5.0 based stroker. Also, I have heard that some of the available seals install dry while others require pre-lubrication around the crank. Does anyone know which is which? Lastly, on what ones should some RTV be applied around the block/seal area?
Here are some seals that I found:
Fel-Pro FPP 2922RS (Fluoroelastomer) $14.88
Fel-Pro FPP 2941 (teflon) $41.69
Fel-Pro BS40620 (rubber) $22.39
Fel-Pro BS40644 (rubber) $22.99
Ford M-6701-B302 $11.88 (Is this the same as stock Ford replacement seals?)
Any response would be appreciated.
