Rear Main Seal Install
bifs66
146
I'm trying to decide what rear seal to install in a 5.0 based stroker. Also, I have heard that some of the available seals install dry while others require pre-lubrication around the crank. Does anyone know which is which? Lastly, on what ones should some RTV be applied around the block/seal area?
Here are some seals that I found:
Fel-Pro FPP 2922RS (Fluoroelastomer) $14.88
Fel-Pro FPP 2941 (teflon) $41.69
Fel-Pro BS40620 (rubber) $22.39
Fel-Pro BS40644 (rubber) $22.99
Ford M-6701-B302 $11.88 (Is this the same as stock Ford replacement seals?)
Any response would be appreciated.
I used the Teflon Fel-Pro when I did my King Cobra clutch install a couple of years ago. It installs dry, no RTV or oil needed (actually, it specifically says NOT to use either). Hasn't leaked a drop at all since. :nice:
It is not going to hurt to put RTV on the outside of the lip, where the block and seal meet.
It can install dry as long as you do not kink the inner lip:nice: So watch for that...
The clutch install link in my signature may help with procedural help getting to the rear main and putting it all back together, and it also includes part numbers.
Use the stock style replacement seal, install it dry but take some vaseline and pack the back side of it all around to keep pressure on the sping. Wipe the excess off and pop it in. You can use this method even with axle seals or pinion seals and you'll never have a problem. Keeps the spring in place, the inner edge from kinking and repels oil away from it. :nice:
