Engine Rear Main Seal: Sleeve or no sleeve
  • Thread starter Thread starter Mustang5L5
  • Start date Start date Jan 23, 2020
First Prev 2 of 2
manicmechanic007
5 Year Member
Sep 26, 2017
2,545
720
143
Roy, Utah
Apr 29, 2025
#21
  • Apr 29, 2025
  • #21
Mustang5L5 said:
I have the old RMS out and about to install a new rear main seal. Just wondering if i should install a sleeve here as well?
I have 100K on the crank/block. I replaced a leaky RMS about 2K miles ago when i did a 5-spd swap. When i pulled the motor a couple months ago, the seak i had previously installed was seeping, but not leaking a whole lot. PCV and other parts are all new, so i don't think i have a crankcase pressure issue on my N/A motor.
Anyway, I have a Ford Racing M-6701-B302 seal, which i believe is OEM since the seal itself has an F1SE part number on it.
I also have a Felpro 21-2100 crank seal, and the Felpro 16300 sleeve install tool.
I've inspected the crank the best i can, and possibly see a wear groove around the circumference. But, the previous seal was leaking a little. Should i install the sleeve? Any downside to installing the sleeve if it wasn't needed? I read it scored the crank, so you will always need to use a sleeve on it.
Generally, seeing "is" believing
But
Your fingernail determines whether or not you need a speedi-sleeve, not your eyes in these cases
Mustang5L5
Mod Dude
Feb 18, 2001
43,305
18,012
224
Massachusetts
Apr 29, 2025
#22
  • Apr 29, 2025
  • #22
4 years old, but I installed the sleeve. No leaks so far.
Reactions: manicmechanic007
First Prev 2 of 2
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Stripped Crank threads and cracked Crank Shaft Ring at end (what is it called?)
  • 69machmike
  • Nov 13, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 19, 2024
89ripper
Engine Rear main seal still dripping, been replaced twice!!
  • AnthonyA1234
  • Jan 5, 2023
12K
Fox 5.0 Mustang Tech Jan 8, 2023
Monkeybutt2000
M
Engine Need RMS repair sleeve
  • evintho
  • Nov 2, 2021
2K
Fox 5.0 Mustang Tech Nov 9, 2021
manicmechanic007
