Rearend howl in turns
ryancabral86
Hey everyone, need some help here cause ford won't help. I bought my 07 Stang GT used with 38,000 on it and I just hit 50,000 and ever since about 42,000 I have been hearing a howl in the rear end when making sharp slow turns. Now its possible that it has been making this noise the whole time and I just didn't notice. Ford is trying to tell me that the limited slip differential in my car is known to make those noises and that ford put out a message to expect that. Has anyone else herd of this?
Not sure if this is what it could be or not, but here goes. I was having the same kind of issue with my 05. Although, I figured out it wasn't just in turns it was anytime I was slowing down. I ended up getting the car up and opening the differential. Every bolt on my ring gear (I think about 8 of them?) were absolutely loose about to fall out. I did replace the gears in my car about 8-9 months ago and torqued those bolts down to specs (I believe 70lb). My guess is that I didn't break in the gears like I was supposed to... :nono: Anyways, tightened all of the bolts again to specs and haven't had an issue since. Again, no clue if this could be your problem or not but figured I would share because the description of your noise sounds alike.
lol... yeah, mine sounded like the wheels rubbing on the wheelwell as well. I actually thought it was a wheelbearing at first and had to go through all of that before I realized it was in the differential.
