Rearend Rebuild
Hello all,
Yesterday I had installed on my '91 LX automatic some 4.10 gears, axles, and a new differential. Now, I am currently in the break in stage, but to me it seems as if the gears are the same thing as what I had on the car. (Which was completely stock). So it almost seems like they got my gears mixed up and installed the wrong ones. If so, how would I be able to tell? And if they are correct, would I feel a major difference right away? Because it seems like the same old long shifts from the old gear sets.
Thanks,
Sean
You said you are in the break in stage, meaning you haven't got on it yet? Wait until you can thrash on it and then you should see a difference. You can Google search it, but you can jack up the car and rotate the rear tires, while counting the drive shaft rotations. You can figure out your gear rato from there.
Joe
Jack up the car, Use jack stands..
Place the car in neutral
Center the valve stem at the peak of the rotation on one wheel.
Make a chalk mark on your drive shaft
Spin the wheel 1 complete revolution while counting the revolutions of the drive shaft
If you have 4.10 gears the drive shaft will spin 4.1 times with one wheel rotation.
If you have 3.73 gears the drive shaft will spin 3.73 times with one wheel rotation.
Etc, Etc, Etc.
Reactions: A5literMan
Joe
Yes I am still breaking it in. I just figured I would feel a difference right away. But I will wait till I can get on it to see. And I will try what you said and count rotations. I might even change the oil sooner than later to check that also.
gears are the best performance bang for the buck. You will notice a big difference. A few things to consider
  • did you change the speedo gear in the trans to compensate for the different gear ratio? If not your speedo will be about 20MPH off at highway speed
  • Know that your trans will now shift sooner in lower gears due the lower gear ratio. You may need to install a shift kit, valve body or at a minumum adjust the TV cable
I haven't really noticed a change in MPH
Yes I figured there would be a change in MPH but I haven't really noticed it. Even though I can only go 50 right now. But yes I have a shift kit in the tranny. I just don't know how to adjust the TV cable unfortunately
If you changed from a 2.73, to a 4.10 it would be night and day across the board from the moment you rolled away. First gear would come immediately, the car would be significantly more spirited. Unless you are babying the thing, the tires will break loose w/ almost no provocation in 1/2.. and the engine will wind it's balls off at 70 mph in 4th.
You could do as 84 T top as recommended to be sure exactly what they put in there but there is no way in hell you wouldn't notice that significant of a gear change even going to church.
