Rearend Springs
I need a good cheap set of springs to put into the mustang. I am doing a 5-lug cobra conversion, with 17x8 rims in the front and 17x9 in the rear. I was going to go with the Eibach Drag Springs, but cant find a set cheap. If I have to then I will spend the money to buy a new set but if there is something cheaper thats similiar, then that will work too. I have also been thinking of the lowering springs but my driveway is too steep to pull it in if i lower it.
Not real sure what you are trying to get to.
Most all aftermarket springs will lower the car. Drag springs, especially the fronts, may not lower it much at all, and will give you more body roll when cornering. Not really much advantage for just street driving.
A set of 4 cyl springs in the front are a good substitute for drag springs, for track use, and will lower a v8 car a bit. Thats what I have.
Sounds like you really want handling springs. They are worth buying, once you figure out what you want to get to.
