You can use the rear end from a 94-98 as the Housings are EXACTLY the same as your 93! If you wanted to keep the rear disc brakes then you would increase your rear end width, but I actually think it looks better with the slightly wider Track, but if you bolt your Stock stuff back up then there will be no difference at all.
