It'll fit, but the Fox rear axle is about 1.5 inches shorter - your rear wheelbase will be smaller. I think the axle tubes & differential are identical, but the SN95 axles are each 3/4" longer. I'm not sure if you can simply swap over the axles from a SN95 and be set.
