rearend swap
  • Thread starter Thread starter jlangholzj
  • Start date Start date Mar 11, 2010
First Prev 2 of 2
A
ajfriz
18
#21
  • Mar 15, 2010
  • #21
jlangholzj said:
let me know how it goes!!! I'm planning on doing this now, out of curiosity, how much did you get yours for?? granted I'll have to prolly pay for if i go directly with a 5 lug, but you never know
I bought a complete 1990 ex highway patrol car for $350 and it had a low mileage 5.0, 5 speed, and this rear. I'm in the process of installing everything in my car before it goes to the paint shop.
lord_cobra said:
Cool. I think that would definitely be the easist swap. Unless the Explorer pumpkin isn't actually offset. I can't tell from the picture. If it is not offset and does not require shortening then that would be the best swap because of the gearing and the disk brakes.
Also I thought that I read somewhere on here that for the fox body swap to 5-lug axles you could use the shorter axles from the rangers or explorers, I could be wrong though.
The explorer rear is definitely offset and can cause problems. There are some people getting vibration at high speed as well as clearance issues with the tunnel if they haven't shortened the one side.
Personally I would just build a fox 8.8 even though the prices of the explorer rear ends are so tempting since you get 5 lug axles, disc brakes, and usually a limited slip. The cost of doing it right and shortening one side and getting a new shaft make it so it really isn't cost effective since you can do a 5 lug swap for super cheap with the fox axle by using ranger or aerostar shafts. If you want a little wider axle, you can use sn95 shafts and disc brakes for super cheap. I see those "kits" all the time on ebay for under $200.
L
lord_cobra
96
Mar 16, 2010
#22
  • Mar 16, 2010
  • #22
Thanks for the great info. Hopefully the OP got what he needed too.
64/2stang
22
#23
  • Mar 16, 2010
  • #23
here is a recent write up on shortning an exploder into a 65 stang with pics.http://www.advancedautorepairsonline...ions 8.8.htm
L
lord_cobra
96
Mar 17, 2010
#24
  • Mar 17, 2010
  • #24
Can you check that link? It does not work because of the ... between online and ions.
N
nugget68
362
#25
  • Mar 17, 2010
  • #25
Restorations 8.8
64/2stang
22
#26
  • Mar 17, 2010
  • #26
nugget68 said:
Restorations 8.8
thats the one. sorry i shouldve checked before i posted.
L
lord_cobra
96
Mar 18, 2010
#27
  • Mar 18, 2010
  • #27
That really doesn't look that bad. I think it would be more beneficial than fixing up an old open 8".
64/2stang
22
#28
  • Mar 18, 2010
  • #28
Looks somewhat easy, maybe gotta hit up the cash for clunker cars. hopefully find 1 complete w/ e-brake and another short axle,
armand67Fstback
146
#29
  • Mar 18, 2010
  • #29
2002 Explorer Rear Axle for a 67 Mustang?
I've read here of using an 8.8 rear axle from a 1996 Explorer. What about a 2002, is that also an 8.8 that will work? I found a 2002 explorer on Craigslist that will be parted out near where I live. If anyone knows please let me know, thanks.
michaelg10
11
#30
  • May 25, 2010
  • #30
I just got mine back from my welder. It was a 31 spline 8.8 out of a 96 Exploder with discs and 373 posi.
Recommend the following:
1. Weld the axle tubes to the center pumpkin (stronger than factory plug welds)
2. Narrow drivers side tube to center the pumpkin in the tunnel; use 2 passenger side axle shafts
3. Reverse the perches 43" apart (for a 67 Mustang)
4. New Bearings and Seals
5. Plan to add a LBW girdle
Still have to rebuild the parking brake shoes and calipers.
I'll post some pictures when I can, it looks awesome. Not nearly as heavy as a 9", I could tell when I carried it in.
First Prev 2 of 2
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
N
1969 15x10 295's for rear. Modifications needed?
  • normg
  • May 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 2, 2026
GypsyR
G
J
1996 v6-v8 swap
  • jujuonurmom
  • Oct 28, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 28, 2025
jujuonurmom
J
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
