rearend
  • Thread starter Thread starter green
  • Start date Start date May 20, 2004
green
291
  • May 20, 2004
hey whats up. i just had a quick question. i own a 85 gt mustang but i only have the small rearend (7.5) inch. the question i was wondering about is would a rearend out of a ford f150 half ton fit under my car. the year like 1989, 1990, 1991. i may be wrong but do they have a 8.8 inch rearend. thanks.
fordman54935
301
Wisconsin
May 20, 2004
  • May 20, 2004
To answer you question in one word......No.
Some Ford pickups were equipped with the 8.8 rear end (the number 7.5 or 8.8 refers to the diameter of the ring gear in inches).
The truck axle would be WAY to wide, the suspension is entirely different (leaf spring in the truck vs. 4-link in the Mustang), the wheel bolt pattern is different, the brakes are much bigger, and the pinion yoke would not work either.
Your best bet is to find an 8.8 out of a wrecked 87-93 5.0 in a junkyard and rebuild it with gears of your choice.
Hope this helps!
M
mike93lx
391
Hudson, MA
May 20, 2004
  • May 20, 2004
try www.stangparts.com they should have everything you need
astronut1885
1,899
Assonet, MA
May 20, 2004
  • May 20, 2004
If by some chance you live in MA, I have an 8.8 in my garage with blown gears that I'll sell cheap. The axles are good, and it's prime for a 3.73 buildup. Only thing it needs besides gears is a diff cover, because that broke when the gears blew.
green
291
  • May 21, 2004
Thanks alot guys. i dident think it would work but id thought id ask to make sure. I live in canada, and it seems to be a bad place for mustang parts, there is nothing around at all. so its pretty hard to get anything. even all the wreck yards have no mustangs in em. later
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
T
Which to keep 1979 Ford Mustang or 2013 VW Jetta TDI Sedan
  • toasterboy1
  • Sep 13, 2025
  • Off-Topic Hangout
Off-Topic Hangout Sep 14, 2025
toasterboy1
T
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
