Hey guys im gettin ready to assembly my engine and i have a few questions. Just so you know its an 88' std bore and i will be using the stock forged TRW pistons. The block was cleaned and checked over by the machine shop and they informed me the cylinders are within stock tolerances and that i should use moly rings. I also had new cam bearings install. They also turned my crank 10/10.
Would these rings be the right size?
http://store.summitracing.com/partde...2D458K&FROM=MG
What should i set the ring gaps to?
Are these the correct bearing for my crank and od bearings?
http://store.summitracing.com/partde...590P10&FROM=MG
http://store.summitracing.com/partde...634P10&FROM=MG x8
Thanks
Bryan
Thanks
Bryan
