I have never rebuilt a carb before, and I don't know the correct names for the parts of the carb. Please help me by correcting my terminology and identifying the parts, thanks!
That said, here are my pics and comments so far. The carb ...
there are 8 of these bolts holding the top down ...
Bolts out, next problem, the lever thing ...
i took this c ring out ... then it fell on the ground and i can't find it!
The underside of the cover ...
There's a little plastic thing that the rod goes through ...
With the cover off ...
The gasket ...
With the gasket off ...
The venturi bolts ... note that they look different ...
They are labeled on the bottom ... "D K" is on the horn side ... it is cleaner ...
"A B" in on the other side ...
This bolt goes on the D K side ...
The undersides of the venturis ...
With the venturis out ...
I took this out next ...
With the venturi gaskets off ....
The A B one has this little gasket, the D K one does not ...
A view of the tubes under the D K venturi ...
The gasket ...
