I was just wondering since I hve time besides carb cleaner what can I use to let my carb soak overnite in so I can make sure that everything is clean. I remember reading a few yrs ago in carcraft or hotrod mag (Idont remember which) that they let it sit in some sort of toilet bowl cleaner? does anybody remember this? if not what is a good solution to let the carb soak in? this is my dads ride and I just wanna make sure tht I do it right for him thanks guys!
I used 85-93 Fox Stang convertable mounts, home built trans cross member, 65-66 Shelby Stang Tri-Y headers, Toploader 4 speed. 88 Crown Vic front acessories ( P/S & Alternator) There are a hundred different ways to V8 a Ranger. Simplest is the 98-up using a V8 Explorer or Mountaineer as a donor. Everything is a bolt in/plug in there. The gallon carb cleaner uses a carb cleaner solution, what it consists of, I can't tell you. Nasty **** though. But washes off with warm water.
