rebuilding my engine
  • Thread starter Thread starter glorkar
  • Start date Start date Jul 23, 2006
G
glorkar
109
Oshkosh, WI
Jul 23, 2006
  • Jul 23, 2006
Okay, so I've decided to rebuild a turbo block for my car (88 lx vert). I've already done the swap, I just want a fresh engine. Any recommendations? I'd like to supe it up a bit, but not too much. She's still only going to be a street beast. Any recommendations on brand of parts is welcome too.
Shawneebear93
20+ Year Stangneter
May 4, 2004
518
17
49
Salisbury Twp, Allentown, PA
Jul 23, 2006
  • Jul 23, 2006
www.northernautoparts.com
EDIT: Sell many rebuilding kits for the 2.3T motors.
88stangmangt
2,332
Stafford,VA
Jul 23, 2006
  • Jul 23, 2006
just did mine...i should take my lazy butt over there and take some pics. ooh i'll give you a tip....everybolt is metric.....just incase you get in a jam....8,10mm are the common ones used...
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Jul 23, 2006
  • Jul 23, 2006
tealtiger, did you mean that link to be to Northern Auto Parts?
Anyway, the only thing I can say about the commercially available rebuild kits is don't get one that has pistons in it. They all come with hypereutectics which are junk in a turbo motor. You can usually reuse the stock pistons, otherwise get some quality aftermarket forged pistons.
Oh yeah, look into porting & polishing the head too. Biggest bottleneck on these engines.
Shawneebear93
20+ Year Stangneter
May 4, 2004
518
17
49
Jul 23, 2006
  • Jul 23, 2006
That is very good information to keep in mind. Thanks!
Oops ... I meant to check that link.
G
glorkar
109
Oshkosh, WI
Jul 23, 2006
  • Jul 23, 2006
"commercially availible" isn't really an issue with me. I just got a job at Competition Products. If you haven't heard of it, it's a mail order perfomance part company like Jegs and Summit. Check it out at http://www.competitionproducts.com The website is still under construction, but our tech guys are great. So anyway, back on topic. Yeah, I can get pretty much anything from any manufacturer for cheap.
Red_LX
73
129
Jul 24, 2006
  • Jul 24, 2006
Well what I was saying was that the "kits" they sell have crappy pistons.
Anyway, I just got all my stuff at Advance Auto Parts. Sealed Power rings & bearings, Fel-Pro gaskets. All good stuff. You might look into gapless rings if you can get them cheap, though.
G
glorkar
109
Oshkosh, WI
Jul 26, 2006
  • Jul 26, 2006
What are your opinion on boring and stroking the engine? I know I've seen stroker kits (2.5, 2.7, 3.0?) on Esslinger's site.
Red_LX
73
129
Jul 27, 2006
  • Jul 27, 2006
Stroking...well, I suppose if you have a couple grand burning a hole in your pocket, go for it. I don't think the cost-to-power ratio of one of the stroker kits is very cost effective personally. You'd be better off spending $1000 on an aluminum head than $2000+ on a stroker kit.
As for boring it should only be done if absolutely necessary (deep scratches in the bores for example), and then, you can't go more than .030" over.
G
glorkar
109
Oshkosh, WI
Jul 30, 2006
#10
  • Jul 30, 2006
  • #10
gotcha...so pretty much keep it stock is what it sounds like as far as internals go. What about head work though. Would it pay to rework that? I mean, port and polish is a definate, but what about something like putting in bigger valves?
Red_LX
73
129
Jul 30, 2006
#11
  • Jul 30, 2006
  • #11
Head work is a "must have" because the head is the biggest bottleneck in the whole engine, but big valves seem to be a bit of a tossup. A lot of people get them done, but then shrouding is usually even worse when you do go to a bigger valve, so I dunno. The stock valves in the turbo head are already pretty big as it is.
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
Lost my Foxbody
  • Mhalc1
  • Feb 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 17, 2026
Mhalc1
