rebuilt motor problems
mustangsquared
828
new bern nc
just had motor rebuilt (all mods listed in sig)...well now it wont idle....and the coolant tenp gauge wont move. I have adjusted the idle a few times...set it at 850 with normal op temp. Runs fine then ata light will want to stall...but only some of the times. My AFPR went bad so I have a stock one on it so I cant play with the FP.
On a side note...what does the ground wire that goes from the intake to fire wall do (or what is it for)...I noticed it is slightly messed up.
Thanks
I used the Idle screw to set the idle to 850 rpm (with the IAC unplugged)....then reset the TPS to .98v and then reattached the IAC plug. Timing is at 10* BTDC.
I will look for a vacuum leak....I know I need to fix that ground wire (the braided one on the lower intake to fire wall) as it is very loose.
As fot the switch around of radio and AC I did it myself. It is easy if you have a dremel and a few hours of time on your hands. I really need to post a "How to" with some picts since everyone always asks about it. I can give you a step by step if you want it.
That ground wire from the intake to firewall is very important. Have you had hard starting problems?
I would definately be interested in your 'How to' for that radio location!
BTW is that a Pioneer 8800? Nice.
