Refurbrishing window regulator on 67
67rcks
373
When trying to fix the driver side window regulator (failed to close) it turned out a small part needs to be replaced as shown on the photo. I could not find any store that carries it. I don't want whole reproduction regulator. Do you guys have any advice where this can be bought?
This is where window roll handle attaches to the regulator. There is a spring inside that creates a precise resistance to allow window to stay open and still allowing to close it with a light effort. I spent some 3 hours trying to repair it (cleaning + some lubrication). Everyhing is clean and greased but this thing still ain't working
That is the regulator, the rest is merely the window lift. There is a spiral spring inside that allows vertical movement when the crank is turned, but prevents the window from falling down on its own. So far as I know, it not available separately as a repair part, the assumption was, I think, that if this part is shot, the stamped arms and pivot are probably no good, either.
I suppose you could pull a used one out of some other window riser, but be aware they are left and right.
