Relay question
  • Thread starter Thread starter S&B
  • Start date Start date Aug 19, 2006
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Aug 19, 2006
  • Aug 19, 2006
I trying to determine if im using the right relay for my Fuel pump (magnafuel).
Im using a Ford relay Part # FOAB-14B192-AA
it seems to be getting warm/ hot not like melting plastic hot but hot. I did run the pump for about an hour and half in the garage and it just kept going. Just making sure that the relay is not the wrong one or anything. Any advice would be great voltage goes from 12-15 volts at high RPM.
HISSIN50
34
129
Aug 19, 2006
  • Aug 19, 2006
For those of us unfamiliar with that pump, what is the draw of the pump at say 15 volts?
What gauge wiring did you run?
You're not sure what amperage the relay is? That part # looks familiar, but that doesn't mean anything
Is it a SPST relay?
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Aug 19, 2006
  • Aug 19, 2006
HISSIN50 said:
Is it a SPST relay?
I have no clue i just had it laying around...
I used 12 gauge for the power side and an 8 gauge ground for the pump. The relay is controled by the ignition which i used a 14 gauge wire for.
this is the pump i used
http://www.magnafuel.com/products/efi/pumps/MP-4301.htm
I got the pump good for 1,500hp
HISSIN50
34
129
Aug 19, 2006
  • Aug 19, 2006
All of those pumps spec out with little amperage draw - your relay really shouldnt be getting hot unless there's a bad connection or other issue.
Are you sure the relay is wired up correctly?
Good luck.
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Aug 20, 2006
  • Aug 20, 2006
yeah it is, i have a good ground a good 12v turn on signal and the large power wires, its just wierd
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Aug 20, 2006
  • Aug 20, 2006
I'll jump in...my relay also will generate some heat, I just put it to being a common occurence.
M
Where does PCM relay ground to in 93 Fox?
  • MBooze22
  • Dec 23, 2023
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 26, 2023
Boostedpimp
Electrical SUDDENLY FUEL PUMP SHUTTING OFF RANDOMLY
  • PonyGTrider
  • Nov 7, 2023
6K
Fox 5.0 Mustang Tech Feb 10, 2024
Mindseye007
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Engine Help hard/no start runs rough.
  • Mr.Kelley
  • Dec 24, 2023
  • 2 3
6K
Fox 5.0 Mustang Tech May 19, 2024
manicmechanic007
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
14K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
