  • 1994 - 1995 Specific Tech
Relocating battery to trunk
  • Thread starter Thread starter Dan95-5.0
  • Start date Start date Dec 1, 2005
  • 3
First Prev 2 of 3 Next Last
YEAHLOH95
1,249
EVERETT,PA
Dec 3, 2005
#21
  • Dec 3, 2005
  • #21
Am i the only one that thought about the fold down plate not working because it goes up with the trunk ?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 3, 2005
#22
  • Dec 3, 2005
  • #22
lol good point there, it works on the fox bodys tho since theirs stays in 1 spot
Dan95-5.0
1,110
Manitoba, Canada
Dec 3, 2005
#23
  • Dec 3, 2005
  • #23
why wouldnt it work?
let me know what would cause a problem.
urban96
3,464
Syracuse, NY
Dec 3, 2005
#24
  • Dec 3, 2005
  • #24
plate is connected to the trunk lid, your wire yould go up and down every time u opend the trunk
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 3, 2005
#25
  • Dec 3, 2005
  • #25
All he would have to do it run the wires along the underside of the trunk lid over to the side where the battery is at. It wouldnt be as clean as say a fox install, but it will work just fine with the trunk opening and closing i think.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 3, 2005
#26
  • Dec 3, 2005
  • #26
And is it "legal" to have a optima not in a sealed box?
Dan95-5.0
1,110
Manitoba, Canada
Dec 3, 2005
#27
  • Dec 3, 2005
  • #27
that wont be a problem routing the wires. its not like it hasent been done before.
a person on corral by the name of Fast SN-95
heres a link to his pics
http://www.inductionindustries.com/pix/shane/
or better yet his pics here
http://www.inductionindustries.com/pix/shane/P0001419.JPG
http://www.inductionindustries.com/pix/shane/P0001420.JPG
i would rather run the lines a little more cleaner but if not, this will do just fine. with the trunk fully open the lines will be nice and tight against the inside of the trunk. but once closed, it will be probably hanging down in the trunk. time will tell once the car is out of storage so i can start all my new projects
i think it looks rather trick with the switch hidden behind the plate and with the flip down plate i'll have easy access to it.
thanks for the help guys for straightening all this crap out.
BlackVert
5,589
9
98
Bethesda, MD
Dec 4, 2005
#28
  • Dec 4, 2005
  • #28
for a street only car what will never go to the track, is the cut-off switch still a good idea, or can i not worry about it?
xkuntrycowboyx
281
Marion, Indiana
Dec 4, 2005
#29
  • Dec 4, 2005
  • #29
wouldn't the direct feed from the alt to the power on the batt, allow the car to continue running if the motor was turning still powering the alt, and continuing to let the motor run... because even if that master switch is cut, the power will still be flowing from the battery pos. straight to the alt.... ??? just how i see it and wondering what u all think, maybe im retarded..
watchu all think???
mytight95
2,605
Dothan,Al
Dec 5, 2005
#30
  • Dec 5, 2005
  • #30
Guys, i researched this a little, but when i did mine i ran a power wire from the fuse panel, to the battery....throught the interior(in some shielded sleeve), and into the trunk, and then grounded the battery to the quad shock........seems to do the trick for me......then everything remains stock, except for the location of the battery, never had any charging issues or hard starts or anything like that.....i did use 1/0 power cable though...
jason
jason
Eric94GTvert
596
PA, Nazareth
Dec 5, 2005
#31
  • Dec 5, 2005
  • #31
watchu all think???
Think of the alt and bat as one item. They are both used to charge and power the distribution (fuse) box. When the switch is in the off position the wire to the fuse box is completely isolated receiving no power. No power means the coil can't fire, fuel pump can't run, car stops dead etc.
Eric94GTvert
596
PA, Nazareth
Dec 5, 2005
#32
  • Dec 5, 2005
  • #32
The cut off switch would be 100% unnecessary in a street only car. The reason they are required @ the track is for a track employee to kill all power to the car in case of an accident, which stops the fuel pump and keeps you from burning alive.
BlackVert
5,589
9
98
Bethesda, MD
Dec 5, 2005
#33
  • Dec 5, 2005
  • #33
if i'm in an accident, running around the back to switch off the battery is probably not the first thing i'd be thinking about.
so what i'm getting out of this is that it is more dangerous to have the battery in the trunk, especially for a street car. if that is really the case, then i no longer want to relocate my battery.
thanks for the info.
tim95gt
44
Kernersville, NC
Dec 5, 2005
#34
  • Dec 5, 2005
  • #34
having the battery in the trunk is no more dangerous than having it in the engine bay. Basically the cut-off switch is just ading an extra way to kill the power in addition to the ignition key. Mainly so if you wreck the track personel can shut of the car wih out having to try and climb inside to turn it off
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 5, 2005
#35
  • Dec 5, 2005
  • #35
Having it in the back leaves more room for wires to get pinched and things like that.
But i do agree, the point of the cut-off is because they wouldnt be able to climb inside to turn off the ignition.
But on the street, if u get into THAT bad of a wreck, wouldnt the fuel cut off in the trunk shut the car down?
Eric94GTvert
596
PA, Nazareth
Dec 5, 2005
#36
  • Dec 5, 2005
  • #36
Yes, the interia switch would cut the fuel.
Dan95-5.0
1,110
Manitoba, Canada
Dec 5, 2005
#37
  • Dec 5, 2005
  • #37
i was looking at some cutoff switches and found a taylor switch for cheap. it has a Continuous Amps Rating of 180.
i'm thinking about picking it up.
i want to run a switch so this way when i go to the track, they wont be hassling me.
Dan95-5.0
1,110
Manitoba, Canada
Feb 18, 2006
#38
  • Feb 18, 2006
  • #38
alright, what parts am i going to need?
my plan is to run a 175amp switch mounted in the trunk. negative to quad shock. positve to alternator using 2/o welding cable with a inline fuse. positive to kill switch killswitch to fuse box all using 1/o welding cable. then reuse the stock cable from the fuse box to the starter.
what connectors am i going to need?
obvioulsy the battery terminals but what about the eyerings? how many? what size?
anything else i'm going to need?
M
Monsterbishi
107
Christchurch, New Zealand
Feb 18, 2006
#39
  • Feb 18, 2006
  • #39
Cool, I love it when old threads are resurrected
Battery relocation has a couple of factors that need to be considered:
1. If mounted behind the rear axle - it will hurt handling
2. If you're a weight reduction junkie the cable will add a few lbs
3. The cable must be secured to the body at certain intervals depending on your local law - usually it's every 10-12"
4. If your battery/trunk is not sealed - then the battery box must be vented to outside the cabin
5. Check the rules at your local track too, they may require the use of a external sticker to indicate the batterys location to safety marshalls.
YEAHLOH95
1,249
EVERETT,PA
Feb 18, 2006
#40
  • Feb 18, 2006
  • #40
1. If mounted behind the rear axle - it will hurt handling2. If you're a weight reduction junkie the cable will add a few lbs
it will not hurt handling it will help equal the front to rear weight bias
  • 3
Big Posi and Neg wire from Starter to Battery and Alt wires..........
  • from6to8
  • Feb 9, 2026
1994 - 1995 Specific Tech Feb 9, 2026
AeroCoupe
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
