YEAHLOH95
Am i the only one that thought about the fold down plate not working because it goes up with the trunk ?
lol good point there, it works on the fox bodys tho since theirs stays in 1 spotYEAHLOH95 said:Am i the only one that thought about the fold down plate not working because it goes up with the trunk ?
xkuntrycowboyx said:![]()
wouldn't the direct feed from the alt to the power on the batt, allow the car to continue running if the motor was turning still powering the alt, and continuing to let the motor run... because even if that master switch is cut, the power will still be flowing from the battery pos. straight to the alt.... ??? just how i see it and wondering what u all think, maybe im retarded..
watchu all think???
BlackVert said:for a street only car what will never go to the track, is the cut-off switch still a good idea, or can i not worry about it?
burning alive.if i'm in an accident, running around the back to switch off the battery is probably not the first thing i'd be thinking about.Eric94GTvert said:The cut off switch would be 100% unnecessary in a street only car. The reason they are required @ the track is for a track employee to kill all power to the car in case of an accident, which stops the fuel pump and keeps you fromburning alive.
tim95gt said:having the battery in the trunk is no more dangerous than having it in the engine bay. Basically the cut-off switch is just ading an extra way to kill the power in addition to the ignition key. Mainly so if you wreck the track personel can shut of the car wih out having to try and climb inside to turn it off
nmcgrawj said:But on the street, if u get into THAT bad of a wreck, wouldnt the fuel cut off in the trunk shut the car down?
Monsterbishi said:Cool, I love it when old threads are resurrected
Battery relocation has a couple of factors that need to be considered:
1. If mounted behind the rear axle - it will hurt handling2. If you're a weight reduction junkie the cable will add a few lbs
3. The cable must be secured to the body at certain intervals depending on your local law - usually it's every 10-12"
4. If your battery/trunk is not sealed - then the battery box must be vented to outside the cabin
5. Check the rules at your local track too, they may require the use of a external sticker to indicate the batterys location to safety marshalls.
