remote door/trunk locks
  • Thread starter Thread starter Daniels1414
  • Start date Start date Jul 24, 2004
D
Daniels1414
31
St. Louis
Jul 24, 2004
  • Jul 24, 2004
I'm looking into putting remote activated door lock actuators in for my doors and trunk. What size seloniod does it take to open a 67 fastbacks doors? In terms of pounds? 15lbs? 35lbs? How about the trunk. Has anyone ever shaved their door handles and used a remote actuator to open them along with the trunk? I did see a kit on www.rodncustom.com/parts_dep/rod_n_cst/DakDig.htm., do you think this will do the job? Thanks for any help. Dan
BlueMonster65
385
Connecticut
Jul 25, 2004
  • Jul 25, 2004
i did. used the vpa kit from summitracing. the 15lb solenoids are good for the mustangs. the kit from VPA is really good and reasonably priced. i didn't get all the fancy stuff just two remotes, reciever, solenoids and wiring and cableing. i added the trunk solenoid for 20 bucks and it came with all the stuff to interface with the door kit.
P
PCH_Cruiser
69
Palmdale, CA
Jul 26, 2004
  • Jul 26, 2004
I'm using these door lock actuators and this trunk solenoid, both from Parts Express. 3 years and no problems.
blandq
146
Houston Texas
Jul 26, 2004
  • Jul 26, 2004
I have only used MES 5-wire door locks. The are European style and swiss made inaddition, the are switch-less and easy to interface into an alarm system. For instance when I hit the arm button it automatically locks the doors and rolls up the windows. Also when I use my ket to unlock the door, the passenger side is also unlocked, put the car in any gear other than park, the doors lock, etc. The five wire gives you a bunch more options than a two wire.
-Q
Gellpak
147
Raleigh, NC
Jul 26, 2004
  • Jul 26, 2004
I heard that using remote window systems has a tendency to eventually burn out your power window regulators... cool idea though, one that I'm still looking into myself...
DarkBuddha
2,215
Seattle & Tampa
Jul 26, 2004
  • Jul 26, 2004
My dad did an electric lock conversion for me using Volvo actuators from the junkyard. He also found a bolt-in electric trunk release at the junkyard, it came as an option on '70s model Fords/Mercurys/Lincolns. To make it all remote, he just wired it up with the security system which has the remote lock option.
Hope this helps.
65 fastback
1,347
Northern VA
Jul 26, 2004
  • Jul 26, 2004
I've got Power door locks, with keyless entry and power windows.
I sourced all of the kits from A-1 Electric - http://www.a1electric.com/ - They should have everything that you are looking for and were the best prices I could find.
Tim
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
R
Electrical OEM Door Lock Actuator Internals/Rebuild?
  • Radau
  • Sep 1, 2023
Fox 5.0 Mustang Tech Sep 1, 2023
Radau
R
I
2 honks when lock (all doors closed)
  • itwillbeclassic
  • Aug 26, 2022
2005 - 2014 S-197 Mustang -General/Talk- Aug 28, 2022
Bullitt347
Viper 791xv Alarm system problems remote start and door trigger false alarm
  • sceprent
  • Jul 2, 2021
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Jul 2, 2021
sceprent
R
Progress Thread Shelby's Mustang - project revived after 7 years...
  • racer_dave
  • Jul 31, 2023
3K
1974 - 1978 Mustang II Talk & Tech May 3, 2025
racer_dave
R
