removal of the egr valve. what will it do
dastang2
2,020
tx
i know little about the egr system. i heard if i remove it, i will have pinging at part throttle. is that true and why does it do that. i also heard it helps on gas mileage and power a little if removed. so i am confused, will it help or hurt. and what about the computer. if it won't ping or anything listen to this idea.i unbolt the 2, 10 mm bolts from the intake and make 2 block off plates. one for the intake and one to block the egr from leaking exhaust. then keep all connections hooked up like wires and hoses. so then if it doesn't work i can just bolt it back easily. would this cause a code if i did it like that. i searched
