remove dashboard and arm rest
  • Thread starter Thread starter peste19
  • Start date Start date Apr 10, 2008
P
peste19
  • Apr 10, 2008
does anyone have a guide or instructions on how to remove these? i was planning on installing a gps system and pass the ipod cable but havent figured out how to remove these. pics would help alot
Thanks in advance
G
GettinThere
553
Central Texas
Apr 10, 2008
  • Apr 10, 2008
Thanks in advance
A Haynes manual, about $17 at most auto parts stores, has a lot of useful information.
J
jprovence
195
Albany, OR
Apr 10, 2008
  • Apr 10, 2008
you mean the center stack and the console?
For the console, Inside the storage compartment, there is the felt, under the felt, there are 2 screws. 5/16 should do it. Pull straight up, then tilt foward enough to get your hand underneight to undo the cig outlet and then you can remove the box.
now pry up on the shifter bezel, the part that attaches to the console. I have pulled mine a hundred times and haven't broke any clips. Just pull straight up and will even controlled force. It will pop off with miniamal force. There are two more screwns toward the top of the console, this will loosed up the console enough to route cableing ect.
Now the center stack, grip the bottom near the TC and defrost buttons, pull toward you with like force from before. This will pop the bezel off. Pull till you hear 4 clips pop. then grab the top of the bezel and pull staight out to pull it from the AC vents. Don't forget to unhook the three switches as the bottom of the stereo bezel if you have them.
This is just from the top of my head. I don't know what year your car is, so I dont know if this is even much help. But its pretty easy to take these cars apart. Ford didn't do alot of R&D on much of anything.
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • dan50
  • Jul 18, 2026
dan50
'67-68 Scott Drake Trap Door w/6x9 Speaker Pods
  • bchampion
  • Jun 15, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jun 16, 2025
bchampion
